ignition problem???
Old 12-05-2010, 04:41 PM
Tod74
Originally Posted by DrivingMissDD
With the engine at an idle, take a breaker bar or chunk of solid steel rod, put one end against your ear and the other upon various locations around each cylinder, on the head, valve cover, and header. I've successfully used this method of isolating noises for years. It's a cheap but effective 'stethoscope'.
good idea. BROOM HANDLE WOrks also
Tod74 is offline
Old 12-05-2010, 04:43 PM
TheYellaBrick
TheYellaBrick's Avatar
I've used both wood and steel but find that steel gives a more refined 'sound transfer'. :shock:
TheYellaBrick is offline
Old 12-05-2010, 06:19 PM
supersmurf666
CRAFTSMAN
tried that today also.couldnt nail down where its coming from yet.gonna do it somemore tomorrow.cant hear it under the truck,can hear it in the wheel well cause it doesnt have any fenderwells in it,and can here it on top.Its for sure coming from the back on the drivers side.
supersmurf666 is offline
Old 12-05-2010, 06:43 PM
Tod74
I have found that the hole in the pan and or block is an even better indicator of where the problem may be.
Tod74 is offline
Old 12-05-2010, 06:54 PM
supersmurf666
CRAFTSMAN
ive also found buttom end parts out the exhaust is a pretty good indicator also.
Old 12-05-2010, 07:01 PM
Tod74
Have you tried turning the lights out while it was running to look see if there is a spark jumping around anywhere?
Tod74 is offline
Old 12-05-2010, 07:35 PM
supersmurf666
CRAFTSMAN
no,i was messing with it in the sunshine today.I will try that though.I did take the number 7 plug wire off the cap and held the plug up by the cap and it got spark....then it jumped to the firwall,in my right hand and out my left hand.LOL!!!!!!
Old 12-06-2010, 06:22 AM
TheYellaBrick
I'm amazed at how many of the simple troubleshooting methods that I forget about !! ops: ops: ops: ops: ops:
Thanks for this reminder, Tod !
Old 12-06-2010, 07:09 AM
zipper06
I've had a loose spark plug do the same sound.
zipper06 is offline
Old 12-06-2010, 12:30 PM
supersmurf666
CRAFTSMAN
well turns out it is a SMALL exhaust leak on number 7 with the super no leak ever gaskets....sure they are!!!Burnt my finger but if you aint burnin you aint learnin............Thanks everybody!!!
